(AJUDA GERAL): Códigos do Datacard
Pessoal, procurei no fórum e não achei, então aí vai:
Encontrei uma relação de códigos de data card com correspondências antigas e atuais. Achei interessante porque ela contém descrições que constam como indisponíveis no site ucraniano. Da minha 123, por exemplo, encontrei os códigos 411 (teto solar manual), 452 (buzina bitonal), 484 (suspensão autonivelante e protetor de cárter) e 674 (bateria tropicalizada), que não apareciam no site ucraniano.
Fonte: [Tens de ter uma conta e sessão iniciada para poderes visualizar este link]
40/1 Interior trimming in leather
40/2 Bench seat
40/2 Tail lamp cable harness for vehicles having front bench seat
41/0 Springs with higher load-carrying capacity
41/0 Sunroof, electric
41/1 Sunroof, mechanical
41/4-7 Hardtop
41/4 Hardtop, separate
41/5 Hardtop, without soft top
41/6 Hardtop, mounted
41/7 Hardtop, for car with rear bench seat
42/0 Body parts used with auto. trans.
42/0 MB auto transmission, central shift
42/0/2 Springs with higher load-carrying capacity
42/1 MB auto transmission, steering column shift
42/2 MB Power steering
42/4 Mech. transmission, central shift
42/5 Mech. transmission, steering column shift
43/0 Front seat safety belts, three-point anchorage, make Kangol (France)
43/0 Safety belts, front & rear
43/1/2 Safety belts (two-point anchorage)
43/1 Safety belts, front
43/2 Safety belts, rear
43/4/5 Safety belts
44/0/5 Bumpers
44/1 Front bumper horn
44/2 Rear bumper horn
45/1 Laminated glass, windshield
45/2 Two-tone horn
45/4 Locking fuel tank
46/1 Instruments in English
46/2 Rear fog lamp
46/3 Hazard warning light
48/0 Hydro pneumatic compensating spring
48/1 Under shields
48/2 H.D. springs and shock absorbers
49/1 Bulbs for headlamps and fog lamps and back-up light
49/1 Combined tail lamps with red blinker light lenses (USA)
49/1 Electrical system for air pollution control
49/1 Fog lamp special wiring
49/1 Fuel tank breathing, USA (LHD)
49/1 Inside rear-view mirror (USA)
49/1 Safety padding
49/1 Springs with higher load-carrying capacity
49/1 Starting-ignition relay (LHD)
49/1 Transistorised ignition for air pollution control
49/1 Warning buzzer, USA (LHD)
49/1 Windshield weather-strip
49/1/5 Gear shift mechanism used with air pollution control (LHD)
49/2 Heater case, high-powered
49/5 Control used with air pollution control device
49/5 Pedal assembly used with air pollution control (USA) (LHD)
49/5 Safety padd1ng
49/5 Side reflectors, side lamps
49/5 Windshield defrosting diagram
49/5/9 Blower switch knob
49/9 Safety padding
49/9 Steering wheel with matt chrome signal ring (USA)
49/9 Windshield defrosting diagram
50/2 Outside mirror, right front, on fender
51/0 Bulbs for headlamps and fog lamps and back-up light
51/1 Radio Becker Mexico (LMKU)
51/4 Radio Becker Europa (LMKU)
51/6 Radio Becker Grand Prix (LMKU)
53/1 Automatic antenna (with radio installation)
53/2 Automatic antenna (without radio installation)
53/3 Short-range interference suppression (subsequent radio installation)
54/0 Intermediate cushion
54/2 Locking glove compartment
55/1 Steering wheel, ivory-colored
56/0 Higher driver's seat
56/1 Reclining seat back, right
56/2 Reclining seat back, left
56/3 Reclining seat back, bench seat
56/5 Transverse seat in rear
57/1/2 Front seat backrest parts used with headrest
57/1 Headrest, right front
57/2 Headrest, left front
57/4 Wheel embellishment rings (4)>
58/2 Radiator shroud
58/3 Folding armrest betw. front seats
58/7 Folding armrest, front, cloth
58/7 Folding armrest, front, MB-Tex
58/7 Folding armrest, front, leather
59/0/1 Windshield (heat-absorbing glass)
59/2 Side window panes (heat-absorbing glass)
59/3 Rear window pane (heat-absorbing glass)
59/4 Front & side window panes (heat-absorbing glass)
59/6 Side & rear window panes (heat-absorbing glass)
59/7 Front, side, & rear window panes (heat-absorbing glass)
60/0 Chrome strips on hardtop
60/2 Supplementary safety device for door locking system
60/3 Radiator shutter
61/1/2 Sealed beam headlamps (USA)
61/3 Headlamps, lighting units
61/3 Lighting units less decorative rims, asymmetrical on the left
61/5 Additional blinker lamps
61/6 Combined tail lamps
62/0/9 Passing light signal system, for Italy and for France
62/1 License plate mounting (USA)
62/9 Combined tail lamps with orange back-up light (France)
62/9 Fog lamp special wiring
62/9 Town horn for France (LHD)
63/0 Radial tires (5)
63/U Warning triangle
64/0 Aluminium disc wheels
64/1 Whitewall tires (5)
64/5 Mud & snow tires (4)
64/6 Spare wheel mounting with 7.OOx15 tire
67/3 High-capacity battery
67/4 High-capacity battery
67/7 High-capacity battery
68/0 D-Shield nationality plate
68/1 Tire pressure instructions in foreign languages
68/2 Fire extinguisher
207 Tire pressure instructions, foreign language
208 Tire pressure instructions, foreign language
212 Rear axle, ratio 3.92
215 Spring suspension with increased ground clearance (harder springs)
219 Brake booster
220 Rear door door contacts
221 Steering lock & filler cap for central locking mechanism
221 Vacuum-controlled central locking
222 First aid box installed
224 Luggage compartment lighting
229 Windshield (heat-absorbing glass)
230 Body parts used with mechanical 5-speed trans. with floor shift
230 Engine mounting used with DB 5-speed transmission
230 Floor shift for DB manual 5-speed transmission
230 Instruments for use with optional road ratios
230 Mechanical 5-speed transmission with floor shift (with code 232)
230 Propeller shaft for use with non-series transmission
230 Speedometer shaft
230 ZF 5-speed transmission
232 Rear axle with ratio 4.08 or 3.92
233 Fog lamp special wiring
235 Electric windows, two
236 Electric windows, four
237 Bucket seats
237 Overtaking signal light for vehicles exported to Austria
238 Bucket seats
244 Floor carpets
246 Rear window (electrically heated)
247 Additional fuse box
247 Rear window (electrically heated)
248 Additional fuse box
248 Rear window electrically heated
249 Additional fuse box
249 Rear window (electrically heated)
249 Rear window pane, heat-absorbing & electrically heated
252 Becker "Europa" stereo AM-FM with cassette player
255 Instruments for use with optional road ratios
255 Rear axle, ratio 3.69
256 Rear axle with limited-slip differential
257 Frigiking air conditioner
257 Radiator shroud
258 A/C (ThermoKing)
260 No type designation on rear lid
262 Shielded regulator and cut-out for alternator
263 400 watt generator
264 Reinforced clutch
269 Roof rack
270 Cover for roof rack
271 Instrument panel (knotted walnut veneer)
274 Lengthened seat guide (rails for front seat shifted toward the rear)
275 Driver's seat with strip steel springs (lower)
278 Orthopaedic backrest, left front seat
279 Mechanical antenna on front fender
280 Trunk set, three-piece, for 250SL
281 Trunk set, three-piece, for 250SL with rear bench seat
282 Trunk set, six-piece, for Coupe or sedan
283 Trunk set, four-piece, for 250SL with rear bench seat with folding back
284 Trunk set, five-piece, for Cabriolet
285 Trunk set, six-piece
286 Parcel nets behind driver's seat (2 pieces)
289 Ski fixture
291 Suitcase
292 Medium size vanity case
293 Small vanity case
294 Hatbox
295 Necessity case
297 Trunk strap and mountings
298 Trunk strap and mountings
302 Orthopaedic backrest, right front seat
305 Viscous fan coupling
305 Hydraulic fan coupling
306 A/C hoses
306 A/C (Behr) (with code 305)
306 A/C electrical parts
306 Cable harnesses on US vehicles (LHD)
306 Electrical system used with air conditioner
306 Frigiking air conditioner
306 Radiator shroud
315 Hazard warning light
316 Electronic hazard warning light sender unit and hazard warning
338 Safety belts (USA lap straps), two, front
339 Safety belts (USA lap straps), two, rear
344 Halogen lighting units
344 Headlamps, lighting units
345 Halogen fog lamps
346 Halogen lighting units
395 Interior trimming - leather combined with fabric
404 Orthopaedic backrests, front seat
404L Front seats w/orthopedic back rest
405 Orthopaedic backrests, front seat
405R Front seats w/orthopaedic back rest
410 Electric sliding sun roof w/wind deflector
410 Electric sliding roof
411 Manual sliding sun roof w/wind deflector
411 Sliding roof
420 Body parts for auto. trans. with floor shift
420 Floor carpets
420 Floor shift for automatic transmission
420 Front seat folding armrest (used with floor sh1ft)
420 Instruments for use with opt1onal road ratios
421 Floor carpets
421 Instruments for use with optional road ratios
424 Body parts for manual 4-speed trans. with floor shift
424 Floor carpets
424 Front seat folding armrest (used with floor shift)
428 Engine mounting used with DB 5-speed transmission
428 Floor shift for DB manual 5-speed transmission
428 Mechanical 5-speed transmission with floor shift
428 Speedometer shaft
430 Headrests, rear seat
440 Speedometer shaft
450 Front seat core reinforced (Peerless springing)
452 Two-tone horn
461 English instruments
461 Instruments for use with optional road ratios
462 Rear fog lamp
463 Hazard warning light
466 Vacuum-controlled central locking
471 Export special version I
472 Export special version II
473 Low compression engine
474 Engine altitude parts
481 Under shielding, metal
482 Spring suspension with increased ground clearance
491 Bulbs used for headlamps, fog lamps, and backup light
491 Crystal clear fog lamps (USA)
491 Safety covering
492 Starting ignition relay (LH drive)
492 Heavy duty heat exchanger
495 Safety covering
499 Safety covering
502 Outside rear-view m1rror
503 Outside rear-view mirror
510 Becker "Monte Carlo" (M)
512 Becker "Brescia" (M)
513 Becker "Europa" stereo AM-FM
515 Becker "Europa" AM-FM
517 Becker "Monte Carlo" (LM)
518 Becker "Mexico" cassette AM-FM stereo
519 Becker Grand Prix AM-FM stereo with cassette player
522 "Reims B" adaptor for short-wave reception
531 Antenna, automatic w/selective height adjustment
531 Antenna on front fender
532 Antenna on front fender
533 Short-range radio suppression
534 Antenna on front fender
540 Seat adapter, between front seats
541 Halogen lighting units
541 Partition net and luggage cover
546 Funnel-Type Gasoline Can (Alboy)
550 Ball head type hitching mechanism w1th electrical fixture (only with 48/0)
551 Ivory-colored steering wheel
551 Front seat core reinforced (Peerless springing)
553 Dust sealing for interior and luggage compartment
561L Reinforced spring frame for seats
562 Front seat core reinforced (Peerless springing)
56ZR Reinforced spring frame for seats
569 Automatic Switch-Off of Fog Lights
570 Arm rest, front centre
570 Front seat folding armrest (long version)
570 Front seat folding armrest (used with floor shift)
571 Front seat & rear seat bench backrest parts for use with headrest
571 Headrests
571 Headrests used for single front seats & rear seat bench
572 Front-seat & rear-seat-bench backrest parts for use with headrest
S72 Headrests used for single front seats & rear seat bench
572 Headrests
573 Headrests used for single front seats & rear seat bench
580 A/C symbol plate
580 Air conditioning
581 A/C (Thermoking)
583 Cable harness for electric windows (USA)
583 Floor carpet
584 Cable harness for electric windows (USA)
584 Floor carpet
584 Windows, electric, front/rear
587 Front seat folding armrest (used with floor shift)
587 Front seat folding armrest (long version)
590 Rear window (electrically heated)
591 Rear window (electrically heated)
592 Rear window (electrically heated)
592 Side windows (heat-absorbing glass)
593 Rear window (electrically heated)
593 Rear window (heat-absorbing glass)
610 Bulbs used for headlamps, fog lamps, and backup light
610 Halogen fog lamps
610 Halogen lighting units
611 Sealed beam headlights for LH traffic
612 Sealed beam headlights for RH traffic
613 Headlamps for countries with LH traffic
616 Combined tail lamps
616 Halogen fog lamps
618 Halogen lighting units
619 Halogen lighting units
620 Headlamps, lighting units
630 Tire pressure instructions, radial tires
633 Warning triangle
636 15-in. disc wheels (only with codes 232 and 482)
636 Wheel discs for 15-in. wheels
640 Spare wheel mounting for 7.00x15 tires & aluminium disc wheels
640 Wheels, light alloy (forged)
641 White-wall tires with code 636
646 15-in. disc wheels
646 Spare wheel mounting for 7.OOx15 tires & aluminium disc wheels
674 Battery for use in tropical countries
677 Battery for use in tropical countries, higher capacity
681 Tire pressure instructions, foreign language
747 Steering wheel, Ivory
755 Hub Cup with Contact Spring and Notched Socket Pin
779 Socket for Inspection Light (in Engine Compartment)
811 Rear speakers with fader control
831 Safety belts
835 Coco mats, front & rear floor
836 Mounted fire extinguisher
839 Lighted glove compartment
843 Rear seat divided 2/3L - 1/3R
844 Folding rear-facing third seat
870L Electrically heated seats
871R Electrically heated seats
872 Electrically-heated rear seat
875 Sticking spotlight
876 Rear courtesy light and door contacts
877 Reading lights in rear
878 Chromium Plated Ornamental Ring for Rim 4.50K x 13
879 Front-seat & rear-seat-bench backrest parts for use with headrest
879 Front seat backrest parts used with headrest
879 Headrests used for single front seats & rear seat bench
879 Headrest, left rear
880 Front seat backrest parts used with headrest
880 Front-seat & rear-seat-bench backrest parts for use with headrest
880 Headrests used for single front seats & rear seat bench
880 Headrest, right rear
887 Low-Pressure Tire (6.40 - 13, 6-Ply)
887 Front seat core reinforced (Peerless springing), left
888 Safety belts
890 Front seat with reinforced spring cores, right
891 Safety belts, front & rear seats
891 Safety belts
892 Safety belts
893 Reinforced bench seat
893 Safety belts, front & rear seats
900 Flagstaff and holder, left
901 Flagstaff and holder, right
902 Standard holder, left
903 Standard holder, right
909 Towing attachment. rear
912 Special signal system for police cars
915 Additional battery
916 Additional battery
947 Standard holder & rod, left
948 Standard holder & rod, right
1128 Ski Racks
1332 Luggage Rack on Roof
1399 Second Spare Wheel Bracket
1412 Fog Lights
1428 Blower for Right Ventilator Duct
1436 Reclining Seat Fittings
1438 Nationality Plate
1439 Headrest
1440 Windshield Washer with Hand Pump
1441 Fitted Suitcases
1463 Glove Compartment Lock
1475 Reversing Light (for Police Cars)
Current data codes:
202 owner's manual and maintenance booklet, German
205 owner's manual and maintenance booklet, English
206 owner's manual and maintenance booklet, Italian
207 owner's manual and maintenance booklet, French
208 owner's manual and maintenance booklet, Spanish
209 owner's manual and maintenance booklet, Portuguese
210 elimination of hardtop
211 automatic limited slip differential (ASD)
212 electronic traction support (ETS)
213 parameter steering
214 self-levelling suspension on rear axle with adaptive damping system (ADS)
215 harder springs
216 self-levelling suspension on front and rear axle with adaptive damping system (ADS)
217 adaptive damping system with self-levelling suspension on rear axle
218 rear axle ratio for France
219 distance control (ART)
220 parktronic system (parking aid)
221 left front seat electrically adjustable
222 right front seat electrically adjustable
223 rear seat backrest and headrests electrically adjustable
224 rear single seats and headrests electrically adjustable
225 straight rear seat backrest
226 footrests in the rear
227 ashtray and cigar lighter in the rear, illuminated
228 auxiliary heater
229 auxiliary heater in the rear
230 remote control for auxiliary heater
231 garage door opener
235 Conti tires for taxi
236 special light wiring, daylight
237 Uniroyal tires for Interrent
239 Michelin tires for Hertz
240 outside temperature indicator
241 left front seat electrically adjustable with memory feature
242 right front seat electrically adjustable with memory feature
243 sports seats in front and rear
244 sports seats in front
245 on-board computer
246 mirror with memory feature
247 electric seat adjustment, additionally adjustable from the rear
248 rear seats with integrated children's seats
249 automatically dipping inside rear view mirror
251 radio MB exquisit, USA
253 radio MB exquisit, Japan
256 rear axle with limited-slip differential
257 radio HI-line
259 radio premium, incl. sound system (Bose)
260 elimination of type sign on trunk lid
261 elimination of V12 sign
262 elimination of parktronic-system (USA)
265 elimination of elegance/sport/esprit/classic sign
269 model designation 600 SE/SEL/SEC on glove compartment lid
270 antenna on rear fender for D-network telephone
272 provision for connection of D-network telephone
273 provision for D-network telephone (handy)
274 Mercedes-Benz D-network telephone
275 memory package (driver's seat, steering column, mirror)
280 steering wheel and gearshift lever in leather trim
281 steering wheel with sports design and gearshift in leather trim
282 ski bag
283 draft deflector
284 wood gearshift
285 ruffled pockets on front seat backrests
286 luggage nets on front seat backrests
287 ski inboard loading facility
288 multiple contour backrest for left and right rear single seats
289 steering wheel and gearshift lever in leather/wooden trim
291 airbag for driver and front passenger
292 side bags for driver and front passenger
293 side bags in the rear (left and right)
295 curtains for left and right rear door windows
296 electrically adjustable curtain for rear windows
298 folding table on front seat backrest, right
300 storage box in front tray
301 storage box in the rear (wood)
302 folding armrest in the rear with storage tray
303 front folding armrest with storage tray
304 elimination of front ashtray
305 dust filter
306 activated charcoal filter (odour filter)
307 cooling box in luggage compartment
308 cooling compartment in centre rear backrest
309 cup holder
310 antenna on rear fender with switch for D-network telephone
313 Mercedes-Benz D-network telephone (handy)
314 Mercedes-Benz D-network telephone
315 telephone card, D2 Debitel
316 D-Network Telephone integrated
323 provision for D-network telephone
325 C-Network telephone Mercedes-Benz
326 front armrest for telephone-handset
328 hands-off system for car phone
329 provision for telephone, export
330 CD compartment in centre console
331 cassette compartment
333 special instrument panel, incl. retrofit cover
335 special housing with tray
340 additional 3rd stop lamp
341 additional turn signal lamps
342 connection for taxi roof sign
343 air cleaner with fill level indicator
344 H4 halogen lamp unit (L.H. traffic)
345 rain sensor for windshield wipers
348 emergency call system
350 communication and navigation system (CNS)
351 auto pilot system
352 operation and monitoring system (OMS)
354 antenna on roof for d-network telephone
355 antenna on rear fender for taxi radio
356 antenna on roof for taxi radio
362 RHD vehicles as per EC regulations (control code)
400 folding armrest in the rear
401 driver's seat air-conditioned
404 multiple contour backrest left
405 multiple contour backrest right
406 code 404 and 405
407 code 400 and 404
408 code 400 and 405
409 code 400, 404, and 405
410 electric sliding roof
411 mechanical sliding roof
412 electric sliding roof with tilting device
414 electric tilting/sliding roof in glass version
415 panoramic glass roof
417 lamellar roof
420 4-speed automatic transmission with tempomat
421 automatic clutch system
423 5-speed automatic transmission with tempomat
425 5-speed automatic transmission
428 5-gear transmission
430 headrests in the rear
431 headrests in the rear, rear left and right automatic (self-reeling) safety s, mechanical lap-type belt
440 tempomat (cruise control)
441 steering column electrically adjustable
442 airbag in steering wheel
443 code 440 and 441
450 international taxi
451 rpm gauge
452 Two-tone horn
460 additional parts, Canada
461 instrument with mileage reading and English lettering
466 central locking system
467 code 461 and 466
470 anti-lock braking system (ABS)
471 acceleration skid control (ASR)
472 electronic stabilizer programme (ESP)
480 self-levelling suspension
481 under shields
482 springs for higher ground clearance
483 code 481 and 482
484 code 480 and 481
486 code 481 and 485
487 active-body-control suspension
489 Self-levelling suspension
490 elimination of windshield heater
491 US version
494 California version
498 Japan version
500 outside rear view mirror, folding
501 outside rear view mirror with memory feature
504 outside rear view mirror, right, electrically adjustable (L.H.D.)
506 outside rear view mirror, left and right, heated (right electrically adjustable), L.H.D.
507 outside rear view mirror, left and right, heated (left electrically adjustable), R.H.D.
508 heated rear view mirrors, left and right
510 radio MB exquist with traffic news decoder (VK), with RDS (Becker)
511 radio MB Exquisit (Panasonic)
512 radio MB special with traffic news decoder (VK), with RDS
515 radio MB classic with traffic news decoder (VK), with RDS
516 radio MB Classic without traffic news decoder, without RDS
518 radio MB Exquisit without traffic news decoder, without RDS
519 radio Mexico Grand Prix, electronic (U.S.A.)
524 paint coat preservation
531 automatic antenna
533 radio-loudspeaker (4 pcs.)
537 mechanically operated antenna and front loudspeaker - without radio set
538 automatic antenna and front loudspeaker - without radio set
540 roller blind, electric, for rear window
541 double roller blind used as luggage and passenger guard
543 sun visor with vanity mirror, illuminated
544 code 540 and 543
547 code 541 and 543
550 trailer coupling
551 anti-theft warning system
552 anti-theft warning system, Switzerland
553 code 550 and 551
554 code 550 and 552
561 front seat, left, reinforced
562 front seat, right, reinforced
563 code 561 and 562
565 cross seat in the rear, rear seats instead of package tray
569 seat package
570 front armrest, folding
571 left front seat with height adjustment (RHD)
572 front seat, right, with seat height adjustment
575 code 570 and 572
580 air conditioner
581 automatic climate control
582 air conditioner in the rear
583 electric window lifters (front doors)
584 electric window lifters (front and rear doors)
585 code 580 and 583
586 code 580 and 584
587 code 581 and 583
588 code 581 and 584
589 code 581 and 582
590 heat-insulating glass, all-around, heated rear window pane (laminated glass)
591 heat-insulating glass, all-around, heated rear window pane, single-sheet safety glass
592 heat-insulating glass, all-around, heated rear window pane (laminated glass), band filter
593 heat-insulating glass, all-around, heated rear window pane, single-sheet safety
594 heat-insulating glass, green, windshield and side window panes
595 heat-insulating glass, green, windshield and side window panes, band filter
598 heat-insulating glass for side window panes and heated rear window pane (ESG),
599 heat-insulating glass for side window panes and heated rear window pane (laminated glass), clear windshield
600 headlamp wiper/washer
602 mounting for customs licence plate
605 code 600 and 602
611 courtesy lamps for front and rear doors
612 xenon headlamps with headlamp washer
613 head-lamp unit, asymmetrically, L.H. traffic
615 code 611 and 613
616 code 611 and 612
617 xenon head-lamps, asymmetrically, L.H. traffic
618 code 611 and 617
619 elimination of xenon head-lamps
620 exhaust emission control
623 Gulf States version
625 Australia version
630 ECE warning triangle
631 bi-chromatic backlights
632 code 630 and 634
634 elimination of first aid box
636 elimination of warning triangle
639 code 634 and 636
640 15-hole light alloy rims
642 7-hole light alloy rims, stellar design
643 205/60 R 15 tires, steel rims
644 code 640 and 645
645 M+S tires (snow tires)
646 7-hole light alloy rims
647 5-hole light alloy rims
649 6-hole light alloy rims
651 sports chassis with steel wheels
652 8-hole light alloy rims
653 sports chassis with 8-hole light alloy rims
654 sports chassis, AMG light alloy wheels, 5-hole
655 sports chassis with light alloy rims, 5-hole
656 light alloy wheels, 10-hole
657 light alloy wheels, 8-hole, 7x15, with 205/60 R15 tires
658 light alloy rims, EVO design
659 5-hole light alloy rims, 18"
660 tires 225/75 R16 with light alloy rims
661 tires 255/65 R16 with light alloy rims
662 tires 275/55 R17 with light alloy rims
663 tires 255/65 R16 with rims chromium-plated
664 tires 275/65 R17 with rims chromium-plated
665 do not put fuel in this vehicle
668 packing for transport
669 spare tire
670 utilization of residual engine heat
671 code 670 and 673
673 high-capacity battery
675 sports suspension with 6-hole light alloy rims
682 fire extinguisher
685 code 682 and 687
687 model plate indicating year of construction
691 heat-insulating glass all around, rear window pane single-sheet safety glass
693 heat-insulating glass all around, band filter grey, rear window pane single-sheet safety glass
700 parts to eliminate on CKD vehicle exported to South Korea
701 SKD vehicles exported to South Korea
702 parts to eliminate on SKD vehicle exported to Vietnam
703 parts to eliminate on SKD vehicle exported to Mexico
704 parts to eliminate on CKD vehicle exported to South-West-Africa
705 parts to eliminate on SKD vehicle exported to R.S.A.
706 parts to eliminate on CKD vehicle exported to Indonesia
707 parts to eliminate on SKD vehicle exported to the Philippines
708 parts to eliminate on CKD vehicle exported to India
709 SKD-vehicles, India
710 parts to eliminate on CKD vehicle exported to Egypt
711 SKD-vehicles, Egypt
715 parts to eliminate on CKD vehicle exported to Thailand
718 parts to eliminate on CKD vehicle exported to Malaysia
719 SKD-vehicles, Indonesia
722 baggage rack, integrated
723 cover for baggage compartment
724 cargo anchorage
725 elimination of roof railing
726 provision for roof luggage rack
731 wood trim, burred walnut root
732 bird-eye maple wood
740 folding top fabric 9001 black
744 folding top fabric 5010 dark blue
746 folding top fabric 8023 dark brown
748 hydraulic folding top
750 radio Europa 2000
751 radio Grand Prix RDS
752 radio Mexico 2000 RDS
753 radio Becker Europa 2000
755 radio MB special with traffic news decoder (VK), with RDS, with CD 4 loudspeakers
772 AMG styling package (front spoiler, slide skirts and rear apron)
773 AMG rear spoiler painted as bodywork
774 body shell modified for AMG wheels
776 wheel cover for AMG wheels
777 rear muffler in AMG design
779 AMG rims, inner section in MB199 blue black metallic
780 AMG sports suspension with 4 AMG light alloy rims and wide tires, 1-piece
781 AMG suspension / wheel package
782 AMG suspension / wheel package
783 AMG sports suspension
784 AMG suspension / wheel package
785 AMG sports suspension with 4 AMG light alloy rims and wide tires
786 AMG sports suspension with 4 AMG light alloy rims and wide tires
787 AMG sports suspension with 4 AMG light alloy rims and wide tires
788 AMG sports suspension with 4 AMG light alloy rims and wide tires
789 AMG sports suspension with 4 AMG light alloy rims and wide tires, 1-piece
790 AMG complete wheels, 7J x 15 ET 37 205/60 , 1-piece
791 AMG complete wheels, 8J x 18 ET 31 235/40 1-piece
792 AMG complete wheels, VA: 8J x 18 ET 31 235/40 ZR18, 1-piece
793 AMG complete wheels
794 AMG light alloy rims, VA: 7,5 J x 17 ET 37 225/45 ZR 17
795 AMG complete wheels, VA 8,5 J x 17 ET 18 235/45 HA 10
796 AMG complete wheels, 7,5x17 ET 42 225/45, 2-piece
797 AMG complete wheels, 8,5 J x 18 ET 44 255/45
798 AMG light alloy rims, 7,5 J x 17 ET 35 225/45, 1-piece
799 AMG light alloy rims, 8,5 J x 18 ET 47 255/45, 1-piece
800 change of model year, the last figure shows the new model year
801 change of model year, the last figure shows the new model year
802 change of model year, the last figure shows the new model year
803 change of model year, the last figure shows the new model year
804 change of model year, the last figure shows the new model year
805 change of model year, the last figure shows the new model year
806 change of model year, the last figure shows the new model year
807 change of model year, the last figure shows the new model year
808 change of model year, the last figure shows the new model year
809 change of model year, the last figure shows the new model year
810 sound package
812 rear-mounted loudspeaker
813 voice control
814 active bass loudspeaker system
816 radio remote control
819 CD changer - in trunk
820 version for tourists (USA, Japan, Australia)
823 additional parts for Switzerland vehicle version
825 additional parts for Sweden vehicle version
826 additional parts for France vehicle version
827 additional parts for Austria vehicle version
828 elimination of exhaust emission control system (CAT)
829 additional parts for Norway vehicle version
831 additional parts for Italy vehicle version
832 additional parts for Denmark vehicle version
833 additional parts for U.K. vehicle version
834 additional parts for Israel vehicle version
835 additional parts for South Korea vehicle version
836 additional parts for Singapore/Hong-Kong vehicle version
837 rubber mats
838 additional parts for Thailand vehicle version
840 glass shaded
841 front guard
842 right front seat with folding backrest
844 folding seat bench in loading compartment
845 elimination of rear seat bench
846 lateral protection
847 3rd seat bench
849 spare wheel, incl. holder
870 facsimile system in rear armrest
871 facsimile system in console
872 heater for rear seat bench
873 seat heater
875 windshield washer heated
876 lamp in the rear
877 reading lamp in the rear
878 cardanic spot lamp in the rear
880 locking system with infrared remote control
882 passenger compartment protection / towing-off protection
883 servo locking system for doors and trunk lid
884 trunk lid additional locking mechanism (HZS)
885 locking system with infrared remote control and immobiliser
886 remote control for trunk lid (opener)
887 lockable safe box
888 infrared remote control
889 keyless go
902 pennant holder, left
903 pennant holder, right
904 special edition "Mille Miglia"
905 special edition "ATP Tour"
906 special edition "DTM/JTC 96"
909 radio remote control, export
910 alternator with increased capacity
911 note concerning special units
912 springs for increased payload
913 air conditioner, provision for installation (ZSM)
914 brake assist
915 fuel tank with increased capacity
916 additional parts for vehicles exported to hot countries
920 engine with exhaust air-pump
921 vegetable oil methyl ester version
922 taxi engine OM604 D22 with power reduction
931 inside tandem rear view mirror
932 box on left front seat
934 taxi emergency alarm unit
935 provision for taxi emergency alarm unit
936 box in tray
937 reinforcement package for taxi
938 radiophone-switch and microphone
939 storage box below the front seat, right
947 pennant holder and pennant staff on the left
948 pennant holder and pennant staff on the right
952 sport line package
953 sport line package
954 equipment package avant-garde
955 equipment package Elegance
956 equipment package sport
957 AMG-Technic Package
959 equipment package esprit
960 version for authorities
961 SINFO roof superstructure
962 HELLA roof superstructure
966 rotating emergency flasher, blue
970 radio patrol car, Germany
971 radio patrol car, export
972 CID version
973 radio patrol car with SINFO unit
974 fire-brigade's chief car
975 emergency doctor's car
978 chassis special version
979 safety version
980 vehicle registration book and general operating permit no. on type plate
981 elimination of vehicle registration book and without general operating permit 982 additional parts for Finland vehicle version
984 elimination of ownership certificate but with COC papers
986 identification plate (VIN no.)
987 battery cut-off switch for vehicles to be shipped
988 ownership certificate and COC papers with EC model plate
993 AMG specific options
994 exhibition car (chassis)
997 exhibition car (chassis and engine)
40/2 Bench seat
41/4-7 Hardtop
43/4/5 Safety belts
44/0/5 Bumpers
45/2 Two-tone horn
46/2 Rear fog lamp
48/1 Under shields
49/1 Safety padding
49/5 Safety padd1ng
49/9 Safety padding
219 Brake booster
237 Bucket seats
238 Bucket seats
244 Floor carpets
257 Radiator shroud
269 Roof rack
289 Ski fixture
291 Suitcase
294 Hatbox
295 Necessity case
306 A/C hoses
306 Radiator shroud
411 Sliding roof
420 Floor carpets
421 Floor carpets
424 Floor carpets
452 Two-tone horn
462 Rear fog lamp
491 Safety covering
495 Safety covering
499 Safety covering
571 Headrests
572 Headrests
583 Floor carpet
584 Floor carpet
831 Safety belts
888 Safety belts
891 Safety belts
892 Safety belts
1128 Ski Racks
1412 Fog Lights
1439 Headrest
Current data codes:
215 harder springs
257 radio HI-line
282 ski bag
283 draft deflector
284 wood gearshift
305 dust filter
309 cup holder
417 lamellar roof
451 rpm gauge
452 Two-tone horn
481 under shields
491 US version
498 Japan version
569 seat package
580 air conditioner
669 spare tire
724 cargo anchorage
810 sound package
813 voice control
837 rubber mats
840 glass shaded
841 front guard
847 3rd seat bench
873 seat heater
889 keyless go
914 brake assist
936 box in tray
972 CID version
979 safety version
Guilhermino- Usuário Ouro
» (AJUDA GERAL): Catálogo em PDF da Bosch com códigos e aplicações de velas
» (AJUDA GERAL): Catálogo em PDF da Bosch com códigos e aplicações de baterias
» (AJUDA GERAL): Catálogo em PDF da Bosch com códigos e aplicações de filtros
» (AJUDA GERAL): Site americano com códigos e imagens de peças - estilo EPC
» (AJUDA GERAL): Ferramentas originais Mercedes-Benz - tipos e códigos
